Supply pressure to a Plan 32?
Complements of the season to you all!
If you have an ASME B73.1 pump specified with a Plan 32 seal arrangement, how much above the pump discharge pressure does the Plan 32 water supply pressure typically need to be please? I have a figure of 2 Barg in my mind. Thank you.
RE: Supply pressure to a Plan 32?
