Funny rows in NX localization ugii.txt file
I would like to share with you a funny picture from the ugii.txt file.
I create the Hungarian localization for NX8.0 and I found the attached picture. Try to merge the selected rows to one sentence.
John,
what would be this?
The quick lazy dog jumps the fox.
RE: Funny rows in NX localization ugii.txt file
I'm not all that familiar with the actual mechanism used to substitute the text strings, only the general scheme that we use.  If this is a real problem, please contact GTAC.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
The sentence "The quick brown fox jumps over a lazy dog" has been used for many years to test penmanship, then typewriters, and then printers; because it includes the entire english alphabet.
It's probably just in there as a test.
Mark Rief
Product Manager
Siemens PLM
That's quite possible.
BTW, even the English language version of NX uses this same real-time, on-the-fly translation mechanism, just that it 'translates' the original UPPERCASE, as programmed source text, to the Mixed Case format as you see it when running NX.  This was done so that this tool was always part of any testing being done, not just when running a non-English language version of NX.
John R. Baker, P.E.
Industry Sector
Cypress, CA
