a report of set of nodes ?!
Hello all ,
im running a simulation on ABAQUS and i have one set of nodes that i am interested in its results
i want to have in my report just values of a the set of nodes,
actually i defined the set of nodes and called  the variables from field output request, but i end up with something like that :
               1        No Value    -3.09315E-03
               2        No Value              0.
               3        No Value              0.
               4       -500.E-03     491.267E-03
               5        No Value              0.
how can i get just nodes (like node #4)i.e i dont need "No value" in my report file.
thankx in advance
RE: a report of set of nodes ?!
Show the lines from your input file that print these values out. I've seen this before and think you need to have separate lines for each output variable.
thankx for reply corus ,
actually i didnt understand exactly what u mean, but the case is more complicated, what if i want to print these integration points values of a surface, so i dont know which points belongs to which surface (by looking at coordinates) !!
the only safe thing i can do, is make a set of these integration points ( of a surface in GUI mode ) then i will be stucked again in same problem ! :(
