Dimension Associativity NX7.5
When dimensioning a Counterbore hole, is there a way that all the dimensions can be associative in one note rather than have to dimension in three seperate places?
Note example consist of : 2 HOLES DIA. 9 CBORE DIA. 20 X 25 DEEP
This note would be associative to the DIA. 9 but no the DIA.20 or the depth.
This is important for updating drawings so that notes update with the change in through hole, counterbore hole and counterbore depth.
RE: Dimension Associativity NX7.5
Insert -> Dimension -> Feature Parameters...
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Depending on how the feature was created, John's suggestion is the better one to use.
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
Any more direction? If possible a video on how it is done would be great.
