Post Tensioned Slabs - Max precompression
ACI 318 18.12.4 sets the lower limit of precompression force in a post tensioned slab at 125 psi, but I don't see any mention of the upper limit anywhere in the code. I read somewhere that the recommended maximum precompression force is 300 psi for slabs. Does anyone know if this is true and if it only a recommeded value as opposed to something that needs to be followed strictly.
RE: Post Tensioned Slabs - Max precompression
Higher moment required to overcome the compressive stress and start cracking the concrete (servicability against corrosion and water retention structures).
Lower deflections available.
