Volume Ratio Effect
Volume Ratio Effect
I am trying to understand the reasoning behind Volume ratio effects in multistage centrifugal compressors. I believe if the gas density changes so does the polyhead curve on these compressors. But I am practically trying to understand in simple terms what actually do volume ratio affects stand for...Do they represent a change in the suction volume for subsequent stages. Does low or high flow go into the other stages depending on changes in gas properties as lets say compared to the first stage....
thank you
thank you
RE: Volume Ratio Effect
Only put off until tomorrow what you are willing to die having left undone. - Pablo Picasso
