Bench top semiconductor prototyping
Is it possible to make a bench-top machine that puts out semiconductors in unit quantities? Ideally, it would take a silicon 'blank' and some source of metals and dopants, and fabricate a finished device via ion implant and soft-landing ion deposition.
Do you think it's possible? Has such a thing ever been proposed or prototyped? What would the major stumbling blocks be?
Thanks.
Thanks.
RE: Bench top semiconductor prototyping
We used to have a lab at school in an EE class where the semester project was making a transistor. Anyone who succeeded in making a BJT got an A.
In general, what you're asking for is not practical outside of a class 100 lab. The chemicals are all toxic, and ion implanter is rather gigantic, an annealing furnace could be desktop, but would still run truckloads of money, and lithography is still a problem.
TTFN
Chinese prisoner wins Nobel Peace Prize
So the toxic materials are only the dopants, and those would be in tiny quantities. I wonder if it can be done using only Al, Si and P?
It doesn't have a practical industrial use. It could be used in space. If it was cheap enough, it could be used for research. I imagine something like an electron microscope, shooting dopants, oxygen or glass, and aluminum instead of electrons.
Dan - Owner
http://www.Hi-TecDesigns.com
Do you think it's possible? = Yes
Has such a thing ever been proposed or prototyped? = probably not
What would the major stumbling blocks be? = beam focus, ion energy control
I expected a bit of pessimism. I'm encouraged by your responses.
For pessimism I'll ask: "what's the point?" A huge part of semiconductor fabrication is tweaking the process into working correctly. Doing "single IC writings" with e-beams, etc., will take umpteen attempts, perhaps each taking a day to finally get a single IC. Then! Almost none of that will transfer to a mass production process.
Keith Cress
I think you can get a 6502 or fancier uP supplied as IP in field-programmable logic already, in a smaller package with a faster clock and a lower power requirement.
The only virtue of geometry as large as what I implied/guessed is that it can be probed manually and observed in action with a relatively low powered microscope, so maybe it has some educational value. ... if you can get the generating machine's price down far enough for education budgets.
So, yeah, it's possible. Maybe using that crowdsourced model where everybody prepays for a kit of parts to fund development of the kit, but we're talking an order of magnitude or six more development money than coming up with a small CNC router in a plywood frame...
Mike Halloran
Pembroke Pines, FL, USA
It doesn't matter, I'm done here. I would happily hear from anyone with design experience in mass specs, electron microscopes and the like. I'll keep an eye out, thanks!
Has such a thing ever been proposed or prototyped? = actually yes, nearly 30 yrs ago. However, practicality is close to nil. You need insulators and metallization, which means you need also plasma/reactive ion etch, sputtering, passivation, annealing, etc. The closest thing to this are the active matrix transistor technology for displays. Hypothetically, one could do something like that with what amounts to an inkjet printer. But to what end? The transistors made with this type of process are barely good enough to crank a display, and nowhere near good enough to build anything with more restrictive requirements.
Power transistors, of any ilk, require precision depositions and anneals, as well as extremely good metallization. Processors require at least 2 layers of metallization, and more likely, 3 layers. An processor of any tolerable performance would require millions of transistors; doing them one by one would be equivalent to watching grass grow. Actually, grass would be faster. 5 million transistors at 10 seconds a pop = 1.58 yrs.
What would the major stumbling blocks be? where to begin? At the minimum, an office desktop system is physically impossible, unless the desktop was at least 100 sq ft in area, and about 8 ft tall:
High vacuum is required for ion implant, as well as plasma etch, as well as metallization. The pumps required to do high vacuum alone would occupy about half of a standard office desktop.
You could potentially get away with using only a laser anneal, but the laser for something like this would occupy at least one desktop's area. Rapid thermal anneal is more likely to be required, again, another desktop's worth of area. Plasma and reactive ion, as well as sputtering require rather massive RF power supplies; another desktop chewed up. A normal ion implanter is rather massive to begin with. The extraction supply alone would take up have a desktop. Direct write on wafer was proposed and demonstrated with e-beam lithography about 40 yrs ago. That alone was another desktop's area gone. I think I've already gone past my initial 100 sq. ft. area estimate.
The fact that you've apparently done zero research prior to posing this question is problematic.
TTFN
TTFN
Dan - Owner
Keith Cress
This process is used during chip design and can reduce the time and cost of debug. Chips are tested; problems found and fixes proposed. Using circuit edit, many repairs on a chip can be tried and proven without having to cut a new mask.
So, similar idea; different application. I haven't heard of anyone using ion beams in the manner suggested. I am not an ion diffusion expert but I know that typically, the energies there are several hundred kV to get adequate implant depth.
I work with scanning electron microscopes and FIBs as described above. 30 to 50 kV is the max energy. Much more than 50 kV and the design rules change drastically as stand-off distance; current or voltage needed to deflect and focus the beam; shielding for ionizing radiation, among other parameters, don't scale linearly. So this might be a limitation.
Maybe this is possible but the machine would be more living room sized than desk top.
Dan - Owner
I would rather avoid annealing it so the dopants would be pre-dilluted in Si. Anyway I was hoping to use just 4 elements: Si, P, Al, O. If I lived on Mars I wouldn't want to have to find Gallium or Indium.
TTFN
