i need to know the torque value??
i have a problem with bolt tightening torque value for 16" & 24" 150lbs with neoprene gasket.
can anyone help me, to find out the torque for the bolts?
RE: i need to know the torque value??
SNORGY.
If so, I would use at least 30% of the bolt yield. I would expect the 16" to use 1", thus about 250 to 350 ft-lbs and the 20" to use 1 1/8", thus about 350 to 475 ft-lbs (with the threads and faces well lubricated with anti-seeze compound)
if no limiter,then gasket compression force is need. If gasket compression pressure is provided, then the gasket dimensisons are needed. assuming 1/2" wide gasket, the above would be about 15Kpsi.
Thus, torque means nothing if you need to clamp load.
Sorry, but to have a better answer more detail is needed.
in an alternating star pattern....lol
