NX Journal - Find Parent Part
I have selected an edge and I have the object tag. How do I find out what the name of the parent part is using NX Journal?
I'm thinking something like:
CODE
Dim part1 As Part = CType(theSession.Parts.FindObject(edge.ToString), Part)
But this doesn't work.
Help!
Jeff
RE: NX Journal - Find Parent Part
Here is a quick journal that allows you to select an edge then lists various properties of the edge including the parent part.
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim lw As ListingWindow = theSession.ListingWindow
Dim myEdge as Edge
        If (SelectEdge(myEdge) = Selection.Response.ObjectSelected) Then
            lw.Open
            lw.WriteLine(myEdge.ToString)
            lw.WriteLine("Owned by Part: " & myEdge.OwningPart.FullPath)
            if myEdge.IsOccurrence then
                lw.WriteLine("Owned by Component: " & myEdge.OwningComponent.Name)
                lw.WriteLine("Component Part Path: " & myEdge.Prototype.OwningPart.FullPath)
            end if
            lw.WriteLine("")
            lw.WriteLine("Edge properties")
            if myEdge.Name = "" then
                lw.WriteLine("Name: <NONE>")
            else
                lw.WriteLine("Name: " & myEdge.Name)
            end if
            lw.WriteLine("Color: " & myEdge.Color)
            lw.WriteLine("Length: " & myEdge.GetLength)
            lw.WriteLine("Layer: " & myEdge.Layer)
            lw.WriteLine("LineFont: " & myEdge.LineFont.ToString)
            lw.WriteLine("LineWidth: " & myEdge.LineWidth.ToString)
            lw.WriteLine("SolidEdgeType: " & myEdge.SolidEdgeType.ToString)
            lw.WriteLine("")
            lw.Close
        Else
            lw.Open
            lw.WriteLine("Selection cancelled")
            lw.WriteLine("")
            lw.Close
        End If
End Sub
    Function SelectEdge(ByRef selectedObject As NXObject) As Selection.Response
        Dim ui As UI = ui.GetUI()
        Dim title As String = "Select an Edge"
        Dim response As Selection.Response
        Dim selectionMask(0) As Selection.MaskTriple
        With selectionMask(0)
            .Type = UFConstants.UF_solid_type
            .Subtype = UFConstants.UF_solid_body_subtype
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_ANY_EDGE
        End With
        Dim cursor As Point3d = Nothing
        response = ui.SelectionManager.SelectObject("Select an Edge", _
            "Select an Edge", Selection.SelectionScope.AnyInAssembly, _
            Selection.SelectionAction.ClearAndEnableSpecific, _
            False, False, selectionMask, selectedObject, cursor)
        Return response
    End Function
End Module
Thanks, I used:
CODE
Dim part1 As Part = CType(theSession.Parts.FindObject(curvObj.Prototype.OwningPart.FullPath), Part)
Based on yours.  It works great!
Jeff
