Constrain Assemblies through .NET
I've written a c# program that allows me to import a number of parts simultaneously into a new assembly. Obviously they are in the correct locations, and I was wondering if there is a way to allow for user selection of edges in order to constrain the items.
Ideally this would be through the .NET interface.
RE: Constrain Assemblies through .NET
NXObject NO = null;
Point3d P3d = new Point3d();
UISession.SelectionManager.SelectObject("Select object", "select", Selection.SelectionScope.AnyInAssembly, true, true, out NO, out P3d);
Also, would anyone be willing to collaborate on some sort of C#/VB.net library of NXOpen functions? The lack of information is staggering!
//Object to be returned with selected objects
NXObject[] NO = null;
//Define Specific masks
Selection.MaskTriple Mask1 = new Selection.MaskTriple();
Mask1.Type = UFConstants.UF_solid_body_subtype;
Mask1.Subtype = 0;
Mask1.SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_ANY_EDGE;
Selection.MaskTriple Mask2 = new Selection.MaskTriple();
Mask2.Type = UFConstants.UF_solid_body_subtype;
Mask2.Subtype = 0;
Mask2.SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_ANY_FACE;
//Add masks to the masktriple collection of masks
Selection.MaskTriple[] MaskCollection = { Mask1, Mask2 };
UISession.SelectionManager.SelectObjects("Select Faces To Mate", "Select 2 Faces",Selection.SelectionScope.AnyInAssembly,Selection.SelectionAction.ClearAndEnableSpecific,true,true,MaskCollection,out NO);
There are some examples in the <NX folder>\UGOPEN\SampleNXOpenApplications\.NET folder. Also, if your maintenance fees are up to date you can access GTAC online where they have several .NET examples.
CODE
Imports System
Imports System.Collections
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim lw As ListingWindow = theSession.ListingWindow
Dim mySelections() as NXObject
Dim myFaces as New ArrayList()
Dim myEdges as New ArrayList()
Dim i as Integer
Dim myFace as Face
Dim myEdge as Edge
If (SelectFaces(mySelections) = Selection.Response.Ok) Then
lw.Open
lw.WriteLine(UBound(mySelections) + 1 & " faces/edges selected")
For each myEntity as NXObject in mySelections
'lw.WriteLine(myEntity.GetType().ToString)
if myEntity.GetType().ToString = "NXOpen.Face" then
myFaces.Add(myEntity)
elseif myEntity.GetType().ToString = "NXOpen.Edge" then
myEdges.Add(myEntity)
end if
Next
lw.WriteLine("myFaces.Count = " & myFaces.Count)
lw.WriteLine("myEdges.Count = " & myEdges.Count)
lw.WriteLine("")
For Each myFace in myFaces
lw.WriteLine("Face color: " & myFace.Color)
Next
lw.WriteLine("")
For Each myEdge in myEdges
lw.WriteLine("Edge Layer: " & myEdge.Layer)
Next
Else
lw.Open
lw.WriteLine("Selection cancelled")
lw.WriteLine("")
lw.Close
End If
End Sub
Function SelectFaces(ByRef selectedObjects() As NXObject) As Selection.Response
Dim ui As UI = NXOpen.UI.GetUI
Dim message As String = "Select Faces"
Dim title As String = "Selection"
Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
Dim keepHighlighted As Boolean = False
Dim includeFeatures As Boolean = False
Dim resp As Selection.Response
Dim selectionAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
Dim selectionMask_array(1) As Selection.MaskTriple
With selectionMask_array(0)
.Type = UFConstants.UF_solid_type
.Subtype = 0
End With
With selectionMask_array(1)
.Subtype = UFConstants.UF_solid_body_subtype
End With
resp = ui.SelectionManager.SelectObjects(message, title, scope, selectionAction, includeFeatures, keepHighlighted, selectionMask_array, selectedObjects)
Return resp
End Function
End Module
A few things to note:
I am loading parts initially, and BaseParts cannot easily selected by features such as edges. You must create a blank part, then add your base feature as a component(as you should do anyway).
I also coded a way to select circular features and constrain them concentrically, all from .NET. I'll post the code once I get a few of the smaller kinks out of it.
It could be recoded but this is just a rip of what I am using.
CODE
//Bruce Harrison
//12-21-2011
using NXOpen.Assemblies;
using NXOpen.Positioning;
using NXOpenUI;
using NXOpen.UF;
/// <summary>
/// Overly complex method for constraining objects!
/// </summary>
/// <param name="Component1">Newest part to be added to assembly</param>
/// <param name="basePart1">Assembly that will be added to</param>
public void CreateConstraints(Component Component1, BasePart basePart1)
Session MainSession = Session.GetSession();
UI UISession = UI.GetUI();
Part WorkPart = null;
//Object array that will save the selected objects
WorkPart = MainSession.Parts.Work;
WorkPart.Views.WorkView.RenderingStyle = NXOpen.View.RenderingStyleType.ShadedWithEdges;
//Masks that define what is selectable
var MaskCollection = CreateMask();
ComponentPositioner CP1 = WorkPart.ComponentAssembly.Positioner;
CP1.ClearNetwork();
Arrangement Arrangement1 = (Arrangement)WorkPart.ComponentAssembly.Arrangements.FindObject("Arrangement 1");
CP1.PrimaryArrangement = Arrangement1;
CP1.BeginAssemblyConstraints();
MainSession.Preferences.Assemblies.InterpartPositioning = true;
Network Network1 = CP1.EstablishNetwork();
ComponentNetwork CN1 = (ComponentNetwork)Network1;
CN1.DisplayComponent = null;
CN1.NetworkArrangementsMode = ComponentNetwork.ArrangementsMode.Existing;
CN1.MoveObjectsState = true;
//Startup the object selector dialog. need to find a way to limit selection to 2 edges.
UISession.SelectionManager.SelectObjects("Select 2 Circular Edges To Join", "Select 2 Edges", Selection.SelectionScope.AnyInAssembly, Selection.SelectionAction.ClearAndEnableSpecific, true,false, MaskCollection, out NO);
Constraint Constraint1 = CP1.CreateConstraint();
ComponentConstraint CConstraint1 = (ComponentConstraint)Constraint1;
Constraint1.ConstraintType = Constraint.Type.Concentric;
//Begin constraint on first edge
Edge Face1 = (Edge)NO[0];
var Constraint1Ref = CConstraint1.CreateConstraintReference(Component1, Face1, false, false, false);
//Make this edge stationary, the second will move to meet this one
Constraint1Ref.SetFixHint(true);
//Define constraint edge on second surface
Edge Face2 = (Edge)NO[1];
var Constraint2Ref = CConstraint1.CreateConstraintReference(basePart1, Face2, false, false, false);
//flip constraint 180
CConstraint1.FlipAlignment();
//compute constraints
CN1.Solve();
//If part is 180 off, this message box give you the option of flipping it. Need to find a way to see if one part is
//colliding with another to automate this.
var Response = MessageBox.Show("Reverse direction of constraint?", "Reverse Constraint?", MessageBoxButtons.YesNo, MessageBoxIcon.Question);
if (Response == DialogResult.Yes)
CN1.Solve();
//throw away all the extra junk
CP1.ClearNetwork();
CP1.DeleteNonPersistentConstraints();
CP1.EndAssemblyConstraints();
/// <summary>
/// Setup the masks required for manual selection
/// </summary>
/// <returns>Collection of MaskTriple(s)</returns>
private Selection.MaskTriple[] CreateMask()
var Mask1 = new Selection.MaskTriple();
Mask1.Type = UFConstants.UF_solid_type;
Mask1.Subtype = UFConstants.UF_solid_body_subtype;
Selection.MaskTriple[] MaskCollection = { Mask1 };
return MaskCollection;
I have written a program in VB.NET to assemble components using
assembly constraints.
However when i try to run the program , even though all the assembly
constraints gets created successfully and their constraint solver
status as "Solved", Still the parts are distanced apart and they are
not mating.
Any Idea on what i am missing in my code?
I have developed the code mainly by recording journal in NX6.0
