NX Journal - Masking for Edge
I'm trying to learn by example how to do some journalling.  I found an NX code snippet to filter a selection to curves only, but I want to modify it to filter by edges.  Where can I find a good explanation of how NX parses this and how to make changes?
CODE
Function mask_for_curve(ByVal select_ As IntPtr, ByVal userdata As IntPtr) As Integer
        Dim num_triples As Integer = 5
        Dim mask_triples(4) As UFUi.Mask
        mask_triples(0).object_type = UFConstants.UF_line_type
        mask_triples(0).object_subtype = 0
        mask_triples(0).solid_type = 0
        mask_triples(1).object_type = UFConstants.UF_circle_type
        mask_triples(1).object_subtype = 0
        mask_triples(1).solid_type = 0
        mask_triples(2).object_type = UFConstants.UF_conic_type
        mask_triples(2).object_subtype = 0
        mask_triples(2).solid_type = 0
        mask_triples(3).object_type = UFConstants.UF_spline_type
        mask_triples(3).object_subtype = 0
        mask_triples(3).solid_type = 0
        mask_triples(4).object_type = UFConstants.UF_point_type
        mask_triples(4).object_subtype = 0
        mask_triples(4).solid_type = 0
        ufs.Ui.SetSelMask(select_, _
                           UFUi.SelMaskAction.SelMaskClearAndEnableSpecific, num_triples, mask_triples)
        Return UFConstants.UF_UI_SEL_SUCCESS
    End Function
Jeff
RE: NX Journal - Masking for Edge
Nevermind, I just realized I could add:
CODE
mask_triples(5).object_type = UFConstants.UF_solid_type
mask_triples(5).object_subtype = 0
mask_triples(5).solid_type = UFConstants.UF_UI_SEL_FEATURE_ANY_EDGE
I'm good now.
Jeff
If you add that code to the existing code, also change
CODE
Dim num_triples As Integer = 6
Dim mask_triples(5) As UFUi.Mask
The change you made will filter for curves, points, or edges; if you want just edges, delete the filters for curves and points and change the dim statements to:
CODE
Dim num_triples As Integer = 1
Dim mask_triples(0) As UFUi.Mask
