Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your site was well structured and I found what I was looking for in about 2 minutes. I am looking forward to participating with you in the future..."
Geography
BiPolarMoment (Mechanical)
21 Dec 11 10:25
This is a simple question that I'm embarrassed I can't find an answer for. Given a simple hole in a part where I'm interested in more tightly controlling deviation in the 'x' direction than the 'y' direction can I simply do a single segment position tolerance where the first segment one establishes overall deviation in the x-y plane and then a tighter tolerance while omitting the datum corresponding to y?
e.g. ( Datum corresponds to a normal plane of the same direction)
| Pos | Dia .010 | X | Y | Z |
| Pos | .004 | X | Z |
Alternatively, is it permissible to establish the X and Y seperately (effectively creating a linear X/Y tolerance) e.g.
| Pos | .010 | Y | Z |
I can't seem to find references to single segment or composite tolerancing when it relates to a single feature. Linear tolerancing isn't desired as the location is on two centerlines.
Thanks.
KENAT (Mechanical)
21 Dec 11 10:55
You could look at bidirectional positional tolerancing of features (section 5.9 of ASME Y14.5M-1994 7 fig 5-41 if that's the standard you work to).
This will give you a rectangular zone when arguably function by justify an obround zone but I'll leave that up to you to consider.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Belanger (Automotive)
21 Dec 11 11:13
Yeah... bidirectional is what you want (I can provide a picture if you don't have a GD&T reference book handy).  The two-single-segment examples you give aren't the best because the datums are being jumbled around. Think of a physical gaging scenario: the inspector would then have to jiggle the part against different edges for each positional check.  That's not what you want; you want him to set the part in a fixture only once, but then measure it in two directions to two tolerances.
IOW, the datum references given in the positional tolerance don't have to correspond on a one-to-one basis with the tolerance you are after.  They merely tell everyone how to hold the part.
John-Paul Belanger
Geometric Learning Systems
21 Dec 11 14:18
Thanks John, I completely let that portion of the meaning slip my mind.
Close Box
Join Eng-Tips® Today!
Join Us             Close
