repeat region: 2 columns to 1
I made a table in a drawing but no I want to make one column from 2 columns. No &asm.mbr.noun &asm.mbr.description are given in separated columns.
I found by myself a way to do it, but one has te remove the repeat region and that clears the filtered items away.
my way to do:
make table , than write in one column: &asm.mbr.noun &asm.mbr.description
than add repeat region
and than switch syms
Has anyone a better idea to do the same without clearing the repeat region?????
Thanks in advance!!
