unfold using the Nx sheetmetall
I have a question how to unfold flat the attached parasolid file.
This unfold is a pre process for laser cutting and welding. I'm on nx6
regards
RE: unfold using the Nx sheetmetall
You can't unfold that part because it is not "folded". It is a die formed part.
I thaught I could break up some edges to flattern it. Some segmentation and it works- I have no exprience in nx sheetmetal.
There are at least two problems with this part including the fact that the model is not uniform thickness and the large 'toroidal' corners are not something which can be 'unfolded'.  Besides, as has already been alluded to here, this is the sort of part which is formed (or to be more specific 'drawn' using a pair of dies) rather than 'folded-up' from a flat blank.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
You would have to model that as 2 parts and then unfold each one.
The corner cuts can be done so when folded they will form curved corners, but it does take some trial and error to get the flanges in that area just right.
Ben Loosli
That's a fabricated weldment created from multiple pieces.  And besides, those are NOT toroidal corners.
John R. Baker, P.E.
Industry Sector
Cypress, CA
