Any way to add new new config to a batch of parts?
Is there a macro out there that would add a new configuration to multiple parts. It's the same part, just a different material.
Thanks!
Thanks!
RE: Any way to add new new config to a batch of parts?
I think you may need API to do this? I don't know of a current one to use.
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
TOP
CSWP, BSSE
Based on your answer, I'm assuming it's possible to add a configuration to multiple different parts in a single function.
I've only been able to marco the material configuration a single part at a time. I've also tried a few macros that copy properties again, only a single part at a time....but I don't think there's a way to copy configurations from one part to another.
Writing a macro that updates multiple documents is non-trivial and can't be done just with the macro recorder. It requires traversing a folder or a file with a list of file names and it requires getting and setting configuration information. It also requires that there is a consistent organization for the way you do configs.
People with PDM systems have this taken care of by the PDM system.
TOP
CSWP, BSSE
What is your requirements with the configuration and material type. I mean what "Configuration name" and "material details". I can help with a macro that can add the configuration with material to multiple files.
Deepak Gupta
SW 2010 SP4.0 & 2011 SP4.0
Boxer's SolidWorks™ Blog
