Alloy Steel Plating Test Panels
Looking for a source of 1" x 4" x .063" Thick alloy steel test panels with a Nickel of 1.5 - 2.2 or close to that. Any sources? These will be used to verify plating thickness and adhesion of electroless nickel on E4340 material.
Thanks in advance.
Thanks in advance.
RE: Alloy Steel Plating Test Panels
ACT is the usual supplier for test panels. Their standard panels are not alloy steel, nor are they as thick as .063", but they do make specials upon request. I would contact them for a quote:
http:
