UT scan on glass flake
Anybody have experience doing ultrasonic A,B or C scan on the glasflake coating (1000 micron) on the riser to determine the internal conidtion of the riser since the IP cannot be performed on schedule due to operation/process problem. if ultrasonic scans are not the option, any other proved inspection methods?
Hope can shed some light....thanks
RE: UT scan on glass flake
UT for those thicknesses will require a very small transducer, so that obtaining even 10% coverage will be very timeconsuming.
Eddy current might be an option.
