Surgical Blade Design
Im having trouble designing this surgical blade to the specified dimensions. I tried importing the picture as a shetch and tracing the profile of the blade, but the image is 4:1 scale, so when I apply the correct dimensions the sketch blows up. Please advise.
I have another file that details the dimensions of the slot.
htt p://files. engineerin g.com/getf ile.aspx?f older=aa16 4724-59ba- 438d-97c9- 2c437eabdc 4d&fil e=blade_te mplate.png
htt
RE: Surgical Blade Design
You should be able to get close enough eyeballing it.
Cheers,
Anna Wood
SW2011 SP5, Windows 7 x64
http://www.renderbay.com
http://www.solidmuse.com
http://www.phxswug.com
Diego
Draw a horizontal construction line 40.96mm long (O?A length of blade)
Draw vertical construction lines at each end of the horiz line to create an H
Go to Insert > Sketch Picture and select the blade_template.png image
Re-size, rotate and move the image to fit within the H (Close-cropping the image beforehand will make this easier)
Trace and dimension the outline
The slot can be drawn and placed accurately from the given dimensions
http://www.storyofstuff.org/
"the rest is left as an exercise for the student"
Hardie "Crashj" Johnson
SW 2011 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
How is this better than scaling the image to start?
Rather than do it that way round, I think scaling the part he has already drawn would save the extra work of scaling the drawing (and therefore possibly adding further inaccuracy?) then re-doing the tracing part of the task.
Not necessarily better, but possibly, and just another suggestion.
Thanks, all!
It sounds like you are trying to manufacture a blade by reverse engineering it from a competitor's brochure. Are you trying to do this or something like it?
- - -Updraft
