Parenthetical numerals
I've been looking for an answer to this one online for a while now and have come up pretty much empty.
When I was in school, I was taught to write out the words for small numbers, and to use numerals for any number which takes more than three words to say, which means any number over one hundred gets numerals, not words. For example: "The facility generated 2,400 gallons of wastewater during the past twenty-one days."
At times, though, people will write out a number in words, then add numerals in parentheses for clarity. The above example would be written as: "The facility generated two thousand four hundred (2,400) gallons of wastewater during the past twenty-one (21) days."
I can see the value in this format, particularly when the numbers are very large and complicated to write out, but I have seen this taken to silly extremes. I once saw a letter which read: "We should be hearing back from the town in a day or two (2)."
So, does anyone here know of a rule of thumb for this sort of thing?
RE: Parenthetical numerals
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
None of this is perfectly consistent, but that seems to be the tendency.
David
Never start a sentence with a numeral. Spell it out.
Do not repeat spelled-out numbers with numerals.
Spell numbers out less than 10.
If there are two or more numbers in a list, and one of them is greater than 10, use numerals for both.
Applied to engineering, I use numerals for anything that is a measurement. I'm not sure if that's an accepted rule, but it seems to make sense.
I see legalese creeping into engineering communication all the time. Engineering communications should be clear, concise, and accurate--nothing else. It almost seems as though engineering writers see things in legal fine print and think, "Gee, that looks professional. If I write like this, I can't get sued."
WHEREAS legalese writing looks fancy, an engineer's time is better spent writing language that is easy to understand. Language that is easy to understand is generally harder to misuse.
Sometimes style sheets need to be adaptable.
f-d
¡papá gordo ain't no madre flaca!
In your first example above, I think that the proper way to present the information would be "six minutes twelve seconds." You could also write: "I ran the race in 6:12," but that assumes that your reader will know that you mean minutes and seconds rather than six hours and twelve minutes (which might apply if you were running a marathon).
As to your second example "...between nine and 11 minutes," as Erdbau mentioned above, if there are two or more numbers in a list, and one or more of them are over ten, you use numerals for all of them, so the correct way would be: "between 9 and 11 minutes."
Matt
Quality, quantity, cost. Pick two.
LEAK RATE ASSESSED STEADY AT 5(5) LITRES PER MINUTE. THEREFORE ANTICIPATE COMPLETE LOSS OF COOLANT IN APPROX 48(2) HOURS.
If you don't explain which system you're using, not only does it lose all value as a means of spotting errors, but it also leads to confusion.
A.
When I started in engineering in 1980, our bid forms required the contractor to write out the unit cost for each item, then write the numerical values for the unit cost and the extended amount. The total amount bid was also required to be written out and expressed with numbers. The bid form stated that words governed over numbers. As you can imagine, it was quite time-consuming to complete a bid form with 30 or 40 or 50 items, which was typical for the projects we were doing.
In the pre- and early-spreadsheet eras, about half of the bid forms I reviewed had at least one discrepancy between the words and numbers. As soon as I saw the number of errors drop to almost zero, I eliminated the words part from my bid forms. I actually had several contractors call to thank me.
--Winston S. Churchill
So: eleven, twelve, thirteen, fourteen... should be written with letters.
The rest of the cases were already discussed earlier.
saludos.
a.
The only exception would be when a check is less than ten dollars then you still need to write it out.
