Medium Voltage Circuit Breaker Questions.
Q1) I have come accross a medium voltage circuit breaker that originally was installed as a feeder breaker to a building. It is being upgraded right now to provide a feed from a generator. The relays are being swapped out and etc. Can this breaker which has labels stating "line" "load" be swapped?
Q2) Is there anything preventing a different installation from "double lugging" a medium voltage circuit breaker. It has a seperate relay for each set of conductors.
RE: Medium Voltage Circuit Breaker Questions.
A2) I don't understand the question.
Proper generator breakers are available, but they are big and expensive. You might reflect on the reasons why they are big and expensive.
