Produce a *.dat file with reaction results per each subset
Hello;
I need some help. I am modelling a simple structure (in batch mode), loaded in 2 load steps, and I would like to produce a *.dat file with the reaction at the supports. I can do this for a single substep but I need to produce a file with the a reaction value result for each one of the n subtep.
The output should be something like this:
LOAD STEP= 2
SUBSTEP FX FY FZ
1
n
Thanks in advance for your help
Tiago Ferreira
LOAD STEP= 2
SUBSTEP FX FY FZ
1
n
Tiago Ferreira
RE: Produce a *.dat file with reaction results per each subset
Thank-you
Best regards,
Tiago Ferreira
maybe VM201 or VM211 in the Mechanical APDL Verification Manual can help you.
