Thermal analysis problem
Hi everyone,
I have some problems modeling a thermal analysis in Abaqus/CAE.
I want to know the final temp in a plate (0.2x0.2x0.02 m) imported from CATIA V5.
The plate is heated by inner heating rods.
I entered my loads (surface heat flux) on the surface of the holes of the plate (about 2 w/m², all dimensions in meters) : theses are the only information I have.
I dont know how to simulate the ambiant air around my part. I tried interaction ==> surface film condition, but I dont know what to put in "sink temperature" (ambiant air is 20°C, material : steel).
Even if I manage to simulate the ambiant air, do you think I have enough information (a surface heat flux from the heating rod) to do a proper simulation?
Many thanks for your attention/futures answers
RE: Thermal analysis problem
I combined radiation + convection as you said.
But my results still show me the ambiant temperature on the surfaces, which is not accurate (especially with 973°K within the plate, it should be more like 500°K I guess).
Do I have to modelize the ambiant air around my plate by a solid part (to have an overview of the temperature at the surface of my plate)?
TY
