CALCULATING PRESSURE DROP THRU AN INLET SCREEN
I WOULD APPRECIATE ANY HELP ON CALCULATING THE PRESSURE DROP THROUGH AN INLET SCREEN. THE SCREEN IS AT THE INLET OF A WATER TREATMENT PLANT.
CALCULATING PRESSURE DROP THRU AN INLET SCREENCALCULATING PRESSURE DROP THRU AN INLET SCREEN(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: CALCULATING PRESSURE DROP THRU AN INLET SCREEN
Loss Factor(LF)=delp/(rho*(w1^2/2))=1.3*(1-AR)+((1/AR)-1)^2
for Reynolds Number Re=(w0*d/nu)=>1000 where
d=wire diameter
w1= Velocity in duct upstream of screen
w0= Velocity through the open section of the screen
AR= Aduct/Ascreen(open)
For Re values less than 1000, the Loss Factor is multiplied by a plotted Re-dependent value close to 1.0 from Re=1000 to 300 which rises to about 1.23 at Re=100 and to 1.4 at Re=50.
Idelchik gives different symbols for wire diameter, loss factor and area ratio. I've changed them to simplify the description.
