Unknown symbol on board
Working on fixing a small 120v dimmer, and it has a fairly simple circuit, but there's a component I've never seen before.
I think it's some form of diode, but the symbol is like 2 diodes facing each other, IE ->|<- and the part is labeled "DB3"
I need to know how i'd check this component for function. The circuit is just a cap, the DB3, potentiometer, "j1" (transistor?) which I also don't know if i can check, and because of the arrangement of the board, I can't read the numbers on.
Suggestions?
Suggestions?
Byron Morgan - Tupelo, Mississippi
1947 Mayline
SolidWorks 2012
RE: Unknown symbol on board
Why?
The diac symbol looks close (on wikipedia) although the sidac looks closer, except the triangles are both closed. I googled DB3 and it seems to be a "bidirectional trigger diode"...
working on drawing the thing. I'm not an EE obviously, so I'm slow.
1947 Mayline
SolidWorks 2012
The many examples will help you to sort through the one you're dealing with. They're all mostly the same.
PS: ...and then click on Google Images.
It's a gold mine.
The DB3 is from ST Microelectronics.
Cheers,
Benta
Attached is the layout of what I have here. The potentiometer I'm not sure how to represent correctly. there are 2 terminals on bottom and 3 from the edge. The edge center and "high" side are used along with the 2 bottom. Sorry for the roughness of it. Wondering if I would be just as well to build one of these with the diac/triac on perfboard.
dimmer is mine
http:
lamp dimmer is one i might be able to build?
h
1947 Mayline
SolidWorks 2012
Probably not easy if it's the potentiometer.
Gonna guess that the DB3 Diac isn't polarized, right?
1947 Mayline
SolidWorks 2012
Triac bt134 600e
Diac db3 c502
The capacitor only has 333J and 400V on it, it's a dark orange part. What value would that be? 333uF?
1947 Mayline
SolidWorks 2012
333uF @ 400v would be a physically very large capacitor. It's probably 33 x 10^3 pF = 33nf = 0.033uF (many orders of magnitude smaller than your guess).
Thanks for all the help, and hopefully will have good news in a day or two (or next year)
1947 Mayline
SolidWorks 2012
