Trim 8 & Trim 5
Trim 8 & Trim 5
my client requires gate valve with trim 8 with back seat bushing stellited for hydrogen rich service, but my manufacturer has supplied gate valve with trim 5. My manufacturer informs that trim 5 is superior to trim 8 & stelliting back seat bushing is part of trim 5. Can any one give me an idea how to handle this.
RE: Trim 8 & Trim 5
Here's an overview of API trims: h
My focus: Alloy Valves Duplex Valves Monel Valves Inconel Valves Titanium Valves Hastelloy Valves
RE: Trim 8 & Trim 5
Thanks for the valuable summary of information.
On their website, I assume it's just a column / space thing where it references "Hard 41", and that what they really mean is "Hard 410".
SNORGY.
RE: Trim 8 & Trim 5
RE: Trim 8 & Trim 5
I will say I don't think I ever had a customer complain about getting upgraded to trim 5 from trim 8 once it's explained to them
It's still bad form they should let you know it's happening before shipping the valve.
RE: Trim 8 & Trim 5
Many thanks for your valuable suggestion. This is gate valve as per API600. Below is the alternate trim numbers mentioned in API-600 & my client is rejecting based on the below list. I need to convince my client to accept the valve. Could you please give me any other technical point to convince my client.
Specified Trim Number Alternative Trim Number
1 -----------------------8 or 8A
2 -----------------------10
5A ----------------------5
8A ----------------------8
10 ----------------------12 or 16
13 ----------------------14
12 ----------------------16
RE: Trim 8 & Trim 5
RE: Trim 8 & Trim 5
I heard of trim a lot but what exactly is a trim. I tried GOOGLING but dont seem to get a satisfactory answer. In fact nothing. Is there a picture of it or something? In orifice fittings, often times it is stated either standard "A" trim, NACE trim standard or AASG trim. I cant find anything on this through search.
RE: Trim 8 & Trim 5
Here's a couple links that explain it fairly well:
htt
This is from wikipedia (http://en.wikipedia.org/wiki/Valve#Trim)
Trim: The internal elements of a valve are collectively referred to as a valve's trim. According to API Standards 600, "Steel Gate Valve-Flanged and Butt-welding Ends, Bolted Bonnets", the trim consists of stem, seating surface in the body, gate seating surface, bushing or a deposited weld for the backseat and stem hole guide, and small internal parts that normally contact the service fluid, excluding the pin that is used to make a stem-to-gate connection (this pin shall be made of an austenitic stainless steel material).
I know the various trim #s refer to the material used. There are tables available as to which material goes with which trim.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
