Supported VS. Self supported roof of storage tanks
Dear freinds!
As per API 650 2011 5.10.5, a dome or cone roof type with rafter & girder and without column is a supported or self supported roof?
And thk of this roof shall be calculated from 5.10.5 formula or 5+C.A is sufficient?
Regards;
Roohol
RE: Supported VS. Self supported roof of storage tanks
Without any columns it is self-supported.  Even if there are rafters.
3/16-inch [5mm] + C.A. is the thinnest your roof can be.  You have to calc it to be sure that there is sufficient strength present -- supported or self-supporting.
It is not uncommon to see the terminology used either way; if in doubt, ask the person using it to clarify exactly what they mean.
