Need help with adding tapped holes
I need help bolting things together in Pro E Wildfire 4.0.
For example if I go to the carr lane website and download the clamp (550LHTC) and want to assemble it to a base plate.
How do I create tapped holes in the base plate from the position of the clamp.
If I move the clamp in an assembly, I want the holes to move with the clamp.
Any help is appreciated!!
RE: Need help with adding tapped holes
If you want them all to move, you will need to link them with relations.
Ben Loosli
