Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thank you. It's already helped me greatly, and I enjoy just reading the inputs from the other members..."
Geography
Criterion for classifying a beam-column into flexural and compression
DST148 (Structural)
17 Dec 11 23:15
Ref ACI 318-05. The confining reinforcement requirements depend on the type of behavior of the member, namely flexural and compression.  A frame member (beam-column) typically is subjected to both - bending and axial load. I am not aware of any criterion in the Chapters 1 thru' 15 which classifies a member broadly into either a flexural or a compression. However, section 21.3.1.1 classifies a frame member as a flexural  if Pu < (Ag. f'c /10) .
For example a column / pier / pedestal subjected to axial, moment, and shear forces but falls into the category of a flexural member per definition given in 21.3.1.1. Now if shear Vu < (0.5. Phi. Vc) then no shear reinforcing is required in a flexural member per section 11.5.6.1. In that case the ties could be provided just to keep the longitudinal reinforcing in place.
The question is: Can section 21.3.1.1 be used as a criterion for classifying a frame member (beam-column) into either a flexural or a compression member for deciding confining reinforcement requirements? (It is assumed that the member is not part of a LLRS and not in a high seismic risk region)
ash060 (Structural)
19 Dec 11 11:07
It depends on the steel strain. If the steel strain is less than 0.004 than it would be in the transition zone, but it would not meet the requirements of a flexural member so it would be a compression member and have to meet those requirements.
Close Box
Join Eng-Tips® Today!
Join Us             Close
