Definition of material of tube by flow?
Kindly I ask for my friends of this forum.
I'm studing about how define the material of pipe by inner flow?
What procedures are used? I consider the variables, pressure, temperature, flow, and concepts of thermodynamics and fluid mechanics! OK.
As an example: Using a chemical compatibility chart, could see the material (which would be the table, or formula Appreciated by guests for this)? And under pressure, ASME B31.1 and B31.3 I have the formula for thick tubes. However, over the chemistry and temperature when the variable is involved? Use (A Gr.P1 335) or (A Gr.P12 335)? By ASTM have the table of chemical equivalence, such as C 0.08%, 2% Mg, etc.. To define precisely the most suitable material for the tube? Any table, book, file, text, video, informations is welcome, and I will tanks for you very much.
RE: Definition of material of tube by flow?
Perry's Chemical Engineering Handbook has material compatibility information for select services.
- Steve Perry
http://www.linkedin.com/in/stevenhperry
This post is designed to provide accurate and authoritative information in regard to the subject matter covered. It is offered with the understanding that the author is not engaged in rendering engineering or other professional service. If you need help, get help, and PAY FOR IT.
