Coordinates from curve created using NX 7.5?
I know it is very easy to create a data file filled with x,y,z coordinates and then import them into NX in order to create a spline, but is there anyway to do the reverse? Just to clarify...I have a spline that I have created using NX and now I would like to derive a certain number of coordinates from that spline so I could use them to graph that same spline in other programs. Thanks in advance to anyone who can help me! ^___^
RE: Coordinates from curve created using NX 7.5?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
File -> Execute -> Grip...
...and select the .grx file and hit OK. If you have a license to execute GRIP programs the next thing you will see is the Class Selection dialog asking you to select your points.
John R. Baker, P.E.
Industry Sector
Cypress, CA
