Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...It's fun to see others going through the same stuff I did and be able to help. It's also a way for me to stay sharp and not lose the stuff I've learned..."
Geography
"OI Server is not enabled (to enable, unset SDRC_OI_OFF)"
exitRI (Mechanical)
16 Dec 11 18:59
thread577-103203: IGES import error "unset SDRC_OI_OFF"
Hello Everyone:
I know there are many of us out there who are still using I-DEAS NX, so I would like to post a comprehensive answer to a question that I have seen many times over the years.  If you are running I-DEAS NX (ver. 10 or 11) on Windows XP Pro and you see the following error message when attempting to use the data translators:
the following steps can be used to fix this problem permanently.
1) Open a command prompt window and go to your ...I-DEAS/Install directory.
2) Run the OrbixE2AInstall.exe using options /r /f to remove Orbix.
3) Open your Windows Control Panel and go to Administrative Tools>Services. You need to verify that the 4 Iona services have been removed completely before going to the next step.  The 4 Iona Services will be labeled as follows (or similar):
IT iona_services.config_rep.machinename cfr-MyDomain
IT iona_services.locator.machinename MyDomain
IT iona_services.naming.machinename MyDomain
IT iona_services.node_daemon.machinename cfr-MyDomain
If the services still appear in the Services window, they will need to be manually removed using the Registry Editor.  The Iona services are located in your registry under:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services
Select each service and delete it, then close your regedit and restart your computer.
4) After rebooting, open a command prompt window and go back to the ...I-DEAS/install directory and run the OrbixE2AInstall this time using the /i option to reinstall Orbix.
5) When the install is finished, open your Windows Control Panel Services to verify that the 4 Iona services are up and running (if not, start them).  *There should be only 4 Iona services.  If there are more than 4, you missed one while deleting them in the regedit.  You will need to go back to step #1 and repeat.
6) In the Windows Control Panel, go to System>Advanced>Enviroment Variables.  Scroll down through your environment variables until you find one named SDRC_OI_OFF. If this variable exists, delete it and create a new variable named SDRC_OI_ON. Set it's value to 1.
7) Close your Control Panel, reboot your computer, and start a new I-DEAS session.  Your translators will all launch properly.
Close Box
Join Eng-Tips® Today!
Join Us             Close
