Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...If there has ever been a justification needed for access to the net during working hours, just referring to this site should suffice. Fantastic!..."
Geography
Pumping/metering Corrosive ChemicalsHelpful Member!
Vasquezand1 (Mechanical)
15 Dec 11 14:13
We are in the exploratory stage of a project to deliver a specified amount of some chemicals into a mixing tank. We have a few ideas but, in order not to 're-invent the wheel', we would like to bring in some external expertise to advise us on which would be the best solution.  Would someone be able to recommend a company?
15 Dec 11 14:32
Revised: We are in the exploratory stage of a project to pump from a reservoir and deliver a specified amount of some chemicals into a mixing tank. We have a few ideas but, in order not to 're-invent the wheel', we would like to bring in some external expertise to advise us on which would be the best solution.  Would someone be able to recommend a company?
micalbrch (Mechanical)
16 Dec 11 12:11
Some information about flow, head (pressure) and accuracy would be good to guide you into the right direction. But if you just google "metering pumps" you will find a lot of manufacturers. Milton Roy, LEWA, SERA and Prominent are just a few.
ports394 (Mechanical)
20 Dec 11 13:41
I agree with micalbrch.  Build your pit/reservoir out of the right materials for your chemical.  Then use a metering pump (peristaltic style, maybe) and buy the right tubing for that chemical.
Remember this is a positive displacement pump. 1 RPM = 1 constant volume moving forward... ie, PRESSURES INCREASE FAST!   design around that.
As far as a company to do this engineering.  I think that your pump supplier's expertise should be sufficient.
I've had a lot of good experiences using a Moyno progressive-cavity/pd pump for metering, and also with Watson-Marlowe & Masterflex tubing/peristaltic pumps.
Helpful Member!  moltenmetal (Chemical)
21 Dec 11 7:22
Is this a batch or continuous mixing process?  How accurate does your chemical addition need to be?  These are key factors you've not mentioned, and these factors determine a good portion of your design.
If the chemicals are hazardous, focus on means to minimize personnel exposure when handling them, by minimizing the type of handling required.  Pump them directly from the drums or totes that they're supplied in if that's possible.
pumpking (Chemical)
31 Mar 12 2:40
Another option may be an AODD pump with batch controller - try www.ashtonpumps.com as they have recently delivered a few complete packages with control systems for exactly this kind of application - more data needed from you though !
Ash Fenn
www.cdrpumps.co.uk
bimr (Civil/Environmental)
31 Mar 12 9:09
The expertise that you are looking for will depend somewhat on the process that you are involved with, ie. pharmaceutical, biotech, detergents, etc.
You need more than just a pump. In addition, you will need other components such as controls, piping, instruments, etc.
What you need is an industry expert. What industry (process) are you involved with?
PumpSmart (Mechanical)
11 Apr 12 17:30
Vasquezand1,
Do you looking for pump mfg or engineering company to make engineering first?
It seem to be a small project, it is better to do by your own.
If you need a specified amount in a reactor for example, you will use a metering pump if capacity is low.
If your applications fall in capacity of metering pump, you will use:
http://www.pulsafeeder.com/
I hope this helps.
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
