Drawing units in inches using LandDesktop '04
I'm doing traffic sign design, and we can't afford GuidSIGN or any similar package.
Is there a way to dimension objects in inches, instead of feet or meters? I'm getting tired of overriding the dimension text all the time.
Thanks!
Jim
RE: Drawing units in inches using LandDesktop '04
What I've ended up doing for now is drawing it at 1 ft = 1 inch, and overriding the units suffix to show inches rather than feet.
It's a kluge that works, but I'd rather be able to design in inches.
Use the UNITS command, and chose Architectural units for Ft -in-fractions, or Engineering units for Feet - inches.decimal.  then look into your Dimstyles, and set one up that works with the architectural units setting
You can actually just specify a scale factor in your DimStyle to divide by 12.
Switch to metric! ;)
Jeffery V C.E.T.
"If Brute force doesn't solve your problem, your not using enough"
Cadtag and Francesca, thanks for the useful tips!
Jeff, I believe I'm the only one in the office that speaks metric!
As Han Solo said, "Hokey units and archaic measurement systems  are no replacement for a good meter stick at your side, kid."
Or something like that.
