EDIT TEXT IN ENGRAVING IN NX6
3
Hi please any one help me on this,i can not edit text in NX 6
manufacturing once i created from insert-text-,it displays as note,where as in nx5 display as text(can edit).
thanks
RE: EDIT TEXT IN ENGRAVING IN NX6
Can you please provide some more details.
Are you dealing with the annotation text (note), or a text feature (curves from text)?
Exactly what command are you using to edit?
Mark Rief
Product Manager
Siemens PLM
Hi Mark thanks,
I am in NX6 Manufacturing,
I want to engrave letters and nos, I just use from  Insert-text- for engraving.e.g-part no-200 lot no -10,after engraving i want to change it to part no-200 lot no-11,if i double click the text for engraving ,i can not edit the nos.
this can be done in the NX5 but why not in NX6? is there is any option to turn on ?
thanks
@ugcadman,
I'll assume you are doing Insert -> Text when in Manufacturing mode. It creates a drafting note, that when you double click, you get the properties of the note but no way to edit the text.
Try this, switch to drafting mode, cancel the dialog to create a new sheet, then double click the note. You should then be able to change it.
Anthony Galante
Technical Resource Coordinator
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.4.4, Beta NX8.0.0.25
Instead of double click, have you tried right mouse button / Edit ? As Anthony says, the default action is probably Properties.
Mark Rief
Product Manager
Siemens PLM
As anthony pointed out you need to be in Drafting to edit the note.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6.0.5.3
