Laser inspection of various length round rods
We manufacture fiberglass round rods in various lengths and diameters. My QC department has asked me to design 22 different go/no-go setups to check the lengths of our rods. This is just for starters. They range from 9" to 145" in length and need to be held to +/-.015". The diameter range is from 1/2" dia to 2-1/2" dia. I believe there is a laser inspection system out there that will work in this application, but I have searched Google and such and have not found what I need. We need to achieve 100% inspection and the inspection process is done off line and is not automated, yet. If someone could help recommend a laser inspection system that would work for this, that would be great. Thanks in advance.
RE: Laser inspection of various length round rods
how long do you expect the measuring to take (per specimen) ?
why go/no go gauges ? why not just measure them and let the answer tell you good or bad ? (go/no go gauges suggests to me a mechanical set up (like a hole to measure pin diameters ... if the pin doesn't fit, you must reject).
TygerDawg
Blue Technik LLC
Virtuoso Robotics Engineering
www.bluetechnik.com
Thanks, I will look into Keyence.
A mechanical step gauge (go|not) with a pin- adjustable baseline, sort of like one edge of a jig borer's table, would also work. I don't think it would be effective for multiple rods unless you provide a way to orient them parallel and present them singly, like a dual chain conveyor fed by a hopper.
I think you'd best think ahead to how you are going to automate the process in the future, and build a subset of that for use now. Maybe that's where you're going with the laser idea; I don't see a laser bringing much to the party right now.
Mike Halloran
Pembroke Pines, FL, USA
