Large Deflection Under Eccentric Seismic Loading
Hey all,
I currently modelling a low braced frame structure in ETABS with simply supported beams and steel decking.  Under seismic loading in the x and y directions, the building behaves as expected, with reasonable deflections.  However, when I look at deflections in either direction with eccentricity of 10% I get wild deflections (1m or more) in strange locations around the outside of the structure.  The rest of the structure behaves as you would expect; slightly larger deflections overall caused by the eccentricity.
Has anyone experienced similar problems and worked out a solution?
