Carbon print of the production of hollow section steel profile
Which one of these have larger carbon footprint during their production:
Steel Hollow Sections or I sections?
Anyone has some data for this?
thanks
thanks
RE: Carbon print of the production of hollow section steel profile
Most answers to anthropogenic warming questions depend on hopes and dreams rather than engineering/science.
If you know any competent scientists; ask them to calculate the correlation between atmosphereic CO2 (well established) and any global warming curve you pick.
Should I conclude that there is not a significant difference in terms of CO2 production between types of cross sections ? Is it almost the same work to produce any type of cross section?
blacksmith37, I didn't really get your point.. Why should I get calculated the correlation between atmosphereic CO2 and the global warming curve ?
That is correct. The energy (not work) required to produce steel far outweighs the energy requirements for manufacturing processes (product forms). The only exception is if the electrical supply to the mill/fabrication shop is from nuclear plants, in this case the carbon foot print is ZERO.
