One-way torque limiter?
I would like to know if exist a "one way torque limiter".
Basically I'm looking for something that fully engage in
one direction while disengage with torque friction in the other direction.
RE: One-way torque limiter?
Cheers
Greg Locock
http://www.meansindustries.com/OneWayClutch.html
Ted
Thanks for the info. It looks interesting. Just to understand your suggestion. Do you meant that I should combine to element (clutch + Mechanical diode) by myself? I would prefer one single item that I can buy from the shelf.
Ciao
http://www.idicb.com/wrapclbk.htm
A variation of this is what is often used on bicycles with coaster brakes (as GregLocock mentioned), except that the wrap spring is internal and forced to expand against a drum instead of being wrapped around the shaft as on the above site.
Engineering is not the science behind building. It is the science behind not building.
http:/
sorry, I did not fully answer your question. Yes, I would use a combination of a one-way clutch (off-the-shelf) and torque limiter (off-the-shelf) which together would serve both functions; but the suggestions after mine may lead to simpler products. I haven't had the task of finding what you're looking for, so I was just offering different examples of one-way couplings (which do not have the torque limiting function).
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
Take a look at this site:-
http://ww
desertfox
