XYDataFromPath
XYDataFromPath
Hey guys,
I'm using the XYDAtaFromPath quite often to extract data from my output database. But the amount of points in my path isn't always reflected in the length of my XYData object. For example, when I have a path of 1000 points, I sometimes get a XYData object of 1001 or less than 1000 points. Do you have any idea why this can be occuring?
I use 1000 data points in 1 path, because it's a lot faster than 500 times a path of 2 points.
Best regards,
dey
Best regards,
dey
RE: XYDataFromPath
RE: XYDataFromPath
thank you for the quick answer. My nodes are indeed very dense and my points are taken randomly on a circle. Therefore, your explanation seems highly reasonable. I will implement two small changes:
-sort the locations of my path (to get a better path)
-sort the XYDAta object afterwards and throw away identical lines
Do you happen to have any other ways of speeding up the XYDataFromPath method? (Apart from what I described in my first post)
