sketch relationships all red upon creation and cannot edit dimensions
I am having a very strange problem with ST3 right now. When creating a sketch in modeling, all my relationships are red upon creation. Also, when I put a dimension, i cannot edit it. I try and highlight the field when the dimension value comes up and the value gets highlighted sparatically and I cannot enter a value.
I've tried simply reboot my machine, no luck.
RE: sketch relationships all red upon creation and cannot edit dimensions
Are you experiencing the text in the dialog box being highlighted as you move the mouse?
Does it also highlight and rapidly switch between the command finder and zoom slider as well?
Do you use a nVidia Quadro card? Using latest drivers?
Do you use a 3dconnexion mouse?
Sorry for all the questions, trying to find a pattern.
-Haddon
I haven't tried much other that the little bit of work in sketch environment. But it behaves as you stated, highlights quickly when I move my cursor but can't actually edit anything. I'm using a new very generic laptop. So no I don't have Nvidia. Graphics card in my machine is rather week for what I'm doing. But I don't suspect a graphics card issues given the red constraints?...
