Pro/E first and third angle projection
I am looking for advice on configuring my drawing setup to correct the drawing layout which is currently in first angle projection. It appear that the default projection type is set correctly to third angle but it is still creating the drawing views in a first angle projection layout. I have more SW experience than Pro/E and I seem to be missing something that will correct the problem. Any suggestions?
RE: Pro/E first and third angle projection
Note that changing this setting is NOT retroactive. It will only affect the creation of new projection views.
If you already have a detailed drawing with first angle views, you can just move them to the other side.
-J-
Open your drawing template and change it like any other drawing. Remember, it is not retroactive so if the template views are not right you either need to move them or delete them and remake them.
