Make block
Make block
Hi,how do I make a Block?
I´m trying to make
blocks so revision notes ("Issued for construction" etc.)can easily be inserted.
And where shall I save the blocks?
ST4 on a Macbook pro with 8Gb RAM
Yes, it works fine
I´m trying to make
Yes, it works fine
RE: Make block
You can save note in the annotation command.
Patrick
RE: Make block
Do I use "Callout" or "Text" from the Annotaion section on the ribband.
Thanks...
RE: Make block
It can easilly be updated to add rows and columns.
-av8errr
Solid Edge ST3 MP9
xw4600
3GB RAM
Core2Quad CPU 3.00GHz
NVIDIA Quadro FX4800
RE: Make block
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
RE: Make block
Before I put in the text i do not want to have unused lines or rows.
When I put in text REV A, REV B and so on I will have lines and rows around the text.
Solid Edge ST4 Premium
MACBook pro 8GB RAM
RE: Make block
Not saying that's optimum though.
RE: Make block
I have entered all my standard notes and given them names that I can recall them by.
It works great....cheers
Tim
