(911) Power Plant HVAC Failure (911)
Hey Guys,
I am trying to verify some results from a CFD program and the last thing I have is time because it is the end of the fiscal year.
I need to be reminded of the formula for temperature rise in a room. I have a 819CuFt room at 85F. When the power fails, only the secondary HVAC runs which is 300CFM @55F at the vent. The only equipment in the room is two UPS systems generating a total of 7103W (24258BTU/Hr).
How many degrees per hour will the temp rise?
RE: (911) Power Plant HVAC Failure (911)
