where is my user defined view
I've played in NX8 with drawing - explosion Master model drawing from a 3d part. I set up like I ever did in the previous nx version. On the drawing sheet View-> display sheet ->
set up a user defined projection and saved it view -> operarion -> save . Made my explosion. Back on the sheet (view-> display sheet),
add base view I can not find my userdefined view. Where is it to find?
regards
RE: where is my user defined view
You must define the Explosion view in the same part file that the Drawing is located.  In other words, the Explosion view cannot be in the Master Model part file.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
I have placed the exolosion in same part file contains the drawing sheet, thank you on reply.
regards.
yes and no
I found away, but an extra click I have to do compared to nx6,nx7.5
I have to choose the part where I want to take the views from.
I think not really clear why and what this enhancement should help it another extra click...
Since Nx6 I like to use the RMB context on the view....
reg.
