Ammonia and stainless steel, corrosion
Hi there,
hope everything is fine.
Please, I would be grateful if somebody could help me in following topic.
I have red following topic
thread338-273391: ammonia-steel
but I am afraid it doesn't answer completely my question.
Following is the topic:
Ammonia is not corrosive for stainless steel without presence of water or condensate.
From the same topic I can quote
<<Unless you are at extreme temperature, pressures, and concentrations; any SS will have a near zero corrosion rate>>
(mr. EdStainless )
Should water be present with the ammonia, are there risks of corrosion ?
The presence of water be even in form of water condensate.
the stainless steel I would be interested is AISI 304 or AISI 316
Thanks for your help.
RE: Ammonia and stainless steel, corrosion
Ammonia will SCC crack high strength steel (> 100,000 psi tensile) if it does not contain about 50 ppm water (as I remember that in cludes a safety factor).
Many thanks Mr.blacksmith37
Therefore may I understand that water in NH3 somehow improves stainless steel corrosion resistance ?
Many thanks
You don't need water to prevent SCC on stainless steel in ammonia.  It is typically considered resistant to ammonia stress corrosion cracking.
WE had a few large ammonia plants; I don't remember any SS except the reformer furnace tubes/manifolds (HK-40  > HP mod.)
Hello, thanks for all your feedback.
But I am afraid of not getting the point.
If I have a tube in Stainless Steal (AISI 304 or 316) with some water, or water drops, and then I let ammonia passing into the same tube, is the presence of water affecting the corrosion resistance ?
Is it mitigating the corrosive action of ammonia, isn't it ?
Are there any literature references I can refer to ?
many thanks
A small amount of water gives corrosion resistance in carbon steel.
With SS the water is no issue at all (doesn't help or hurt) unless it has some chlorides in it.
Plymouth Tube
