emission sampling ports on stacks of boilers, furnaces and heaters
Dear All,
In one of the job I have to install emission sampling ports on stacks of boilers, furnaces and heaters . I have attached the standard clause with this thread.
First of all I need to understand where the sampling ports should be located. Is it 8 Diameters from the Top of the stack or is it 8 diameters from the bottom?
Secondly how can i determine if the flow inside a stack is cyclonic or not?
thanks
RE: emission sampling ports on stacks of boilers, furnaces and heaters
It should be located a minimum of 8 Diameters downstream from anything that will produce a flow disturbance. If you enter the stack at the base through a 90 degree fitting, it will be 8 pipe diameters above the point where the 90 degree fitting enters the stack.
You can do an EPA test to determine if the flow is cyclonic:
http://www.epa.gov/ttn/emc/prelim/pre-007.pdf
