CUI SELECTS WRONG ICON IMAGE TO EDIT
I have just installed my ACAD 2008 onto a different computer than I was using. It is a win xp machine also. When I tried to customize some icons in the CUI it would select the wrong image to edit. I wanted a SaveAs button and selected that command in the CUI then when I tried to select an icon to modify for it, it would select a different one. It actually wasn't on the small window of icons. I can draw it from scratch, of course, but I was looking for a better starting point.
On this computer I also have ACAD 2009 LT with several icons modified. I had no trouble when I edited them.
What can I do?
One test is worth a thousand expert opinions. - Dan Joos, test engineer
