Referencing min radius - VB Journal
I'm attempting to reference the minimum radius of a selected curve from within a journal... so far, i've tried doing this using CreateCurveCurvatureAnalysisBuilder(), but I was wondering if there was an easier way.
Perhaps "GeometricUtilities.CombOptionsBuilder.AnalysisTypes.Radius"?
RE: Referencing min radius - VB Journal
As a clarification, I have a journal which puts a curve analysis on the selected spline.  I'd like to call the "minimum radius" value from this analysis, for use in a function which adds slack to the spline until the measured value meets or exceeds a given value.
The only one I've found is workPart.FindObject("ENTITY 169 1 1"), but this will only work for a specific instance, of course.
So you just need code to interactively select a spline?
If so, here is an example I downloaded from GTAC a while back.
CODE
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module select_a_spline
    Dim s As Session = Session.GetSession()
    Dim workPart As Part = s.Parts.Work
    Sub Main()
        Dim spline1 As Spline
        If (SelectSpline(spline1) = Selection.Response.ObjectSelected) Then
            Dim nullUnit As Unit = Nothing
            Dim point2 As Point3d = New Point3d(0, 0, 0)
            Dim point1 As Point = workPart.Points.CreatePoint(point2)
            Dim measureDistance1 As MeasureDistance
            measureDistance1 = workPart.MeasureManager.NewDistance(nullUnit, MeasureManager.MeasureType.Maximum, spline1, point1)
            measureDistance1.Information()
            measureDistance1.Dispose()
        End If
    End Sub
    Function SelectSpline(ByRef selectedObject As NXObject) As Selection.Response
        Dim ui As UI = ui.GetUI()
        Dim title As String = "Select a Spline"
        Dim response As Selection.Response
        Dim selectionMask(0) As Selection.MaskTriple
        With selectionMask(0)
            .Type = UFConstants.UF_spline_type
            .Subtype = UFConstants.UF_spline_subtype
            .SolidBodySubtype = 0
        End With
        Dim cursor As Point3d = Nothing
        response = ui.SelectionManager.SelectObject("Select a Spline", _
            "Select a Spline", Selection.SelectionScope.WorkPart, _
            Selection.SelectionAction.ClearAndEnableSpecific, _
            False, False, selectionMask, selectedObject, cursor)
        Return response
    End Function
End Module
This routine prompts the user for a spline then creates a point at (0,0,0) and measures the distance from the point to the spline. The point and measurement code is only there to show that you can do something with the spline now that you have one selected. I hope this helps you out.
Thanks for the reply.
Unfortunately, it's not really the spline that I'm looking to select.
If you use Analysis->Curve->Curve Analysis, there is an option to display minimum radius.  I need the callout for that number.
Doing this to make representation of cable more accurate.  Right now, splines don't seem to obey any kind of bend radius restriction, but I can force them to do so by adding some slack and making the bend larger.  Just trying to automate this process.
Try this journal:
CODE
'eng-tips thread561-312330: Referencing min radius - VB Journal
'journal to determine minimum radius of curvature of selected spline
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
    Dim ufs As UFSession = UFSession.GetUFSession()
    Sub Main()
        'Dim tagList(0) As NXOpen.Tag
        Dim parm as Double
        Dim point(2) as Double
        Dim tangent(2) as Double
        Dim p_norm(2) as Double
        Dim b_norm(2) as Double
        Dim torsion as Double
        Dim radOfCurvature as Double
        Dim minRadOfCurvature as Double
        Dim i as Integer
            'get initial value for minRadOfCurvature
            'set the parameter value we are interested in, value ranges from 0 to 1
            parm = 0
            ufs.modl.AskCurveProps(spline1.tag, parm, point, tangent, p_norm, b_norm, torsion, minRadOfCurvature)
            'loop over the curve in .01 increments
            For i = 1 to 100
                parm = i/100
                ufs.modl.AskCurveProps(spline1.tag, parm, point, tangent, p_norm, b_norm, torsion, radOfCurvature)
                if radOfCurvature < minRadOfCurvature then
                    minRadOfCurvature = radOfCurvature
                end if
            Next
            'show messagebox with minimum radius of curvature
            msgbox(minRadOfCurvature)
        End If
    End Sub
        End With
        Return response
    End Function
End Module
Also, if you are using bridge curves, you can assign a radius constraint but it might take away too much control for what you are after.
This works much better than what I had, thank you very much.
