wall reinforcing corner bars
I am reviewing some drawings for compliance and I have the following situation:
2 walls intersect at a 90 degree angle to form an "L" shape. The horizontal bars from one wall are #6 and the other wall are #7. I can figure the length the corner bars should be by using the tension splice length (given in plans) for each respective side (whether #6 or #7) but I don't know if the corner bar itslef should be a #6 or a #7.
RE: wall reinforcing corner bars
http://www.nceng.com.au/
"A safe structure will be the one whose weakest link is never overloaded by the greatest force to which the structure is subjected" Petroski 1992
Anyhow, I'd use the #7 corner bar unless told otherwise or if I were designing it.
