Cavity Radiation in Abaqus 6.11
I am trying to analyse 3D heat transfer through a clay brick with three circular holes in the centre. There is a boundary condition of 303K set on one side of the brick and then 278K on the other. the analysis worked when I did not set any surface interactions so the holes in the centre were acting as being fully insulated but in real life the holes will act like a cavity. I've set the interactions all up properly (I think!) but the job will not solve and gives me this error:
The model attributes absolute zero temp must be set. It is required for the following interactions:
CantralCavityInteractions
The model attributes Stefan-Boltzmann constant must be set. It is required for the following interactions:
I have these two values but just cant find where to put them in! Is there a icon in the model tree called 'Model Attributes'???
RE: Cavity Radiation in Abaqus 6.11
in the example problems manual
